Question DeepCool AK620 cooler for I9-14900K. Too weak?
It will be fine.
Do note that regardless of the type of cooler, all i9s will run at the temperature of stars specifically when you run all core loads.
[THIS IS AN EXAGGERATION FOR EMPHASIS.]
They are designed to deliver the user maximum performance, even when running at 100C. Thermal shut off is 130C.
Forget what you know about the cpus of yesteryear, they don't apply.
If you aren't comfortable with that all core load behavior, then you can tune the cpu's power limits to your liking in bios.
If you don't want to be tinkering in bios, then perhaps look at a different cpu.
