M MSR01 Jul 18, 2024 3 0 10 Jul 18, 2024 #1 Deepcool Infinity LT720 ARGB vs. Deepcool LT360 ARGB: which one to pick for Ryzen 7 5800X3D? Will there be a performance difference if I change the default fans of the LT720 to RGB?
Lutfij Titan Moderator Oct 7, 2009 61,734 6,963 178,440 Jul 18, 2024 #2 Welcome to the forums, newcomer! How much of a price difference are you seeing between the two listed above? I would get the LT720 but I don't see an LT720 ARGB; https://www.deepcool.com/products/Cooling/index.shtml?filter=true&type=CPULIQUIDCOOLERS in their product portfolio. Upvote 0 Downvote
M MSR01 Jul 18, 2024 3 0 10 Jul 18, 2024 #4 LT720 - Radiator MaterialAluminum Pump Speed3100 RPM±10% Fan Speed500~2250 RPM±10% LT360 - Radiator Material Aluminum Fan Speed 600~2400 RPM±10% Pump Speed 3400 RPM±10% Upvote 0 Downvote
Phaaze88 Titan Ambassador Dec 30, 2016 21,694 5,772 104,690 Jul 18, 2024 #5 The LT720 IS a 360mm AIO. This 'LT360' isn't adding up, unless it's some region-specific part? There IS an L(S)720 though: https://www.deepcool.com/products/C...m-Liquid-CPU-Cooler-1700-AM5/2022/15826.shtml Can you provide a link to this LT360? MSR01 said: Will there be a performance difference if I change the default fans of the LT720 to RGB? Click to expand... Of course, and the acoustics are a little different. Whether you'll even notice them is another matter. Double of course, you would need both fans on hand to tell the differences. Upvote 0 Downvote
