Hi all.
I'm about to upgrade my gaming pc and am looking for a new case. I liked the look of the master case pro 5 but i want my computer to be quiet so i've narrowed it down to the define S and Define R5 from Fractal. In Australia the Define R5 is only $5 more, so i don't see any advantage in the Define S. So what i'm asking is for a person that only has 2 HDDs and 1 SSD, which case is better regarding temperatures (i heard the define s gets a hotspot under the GPU)? and can i put 3 140mm fans in the front of the R5 if i take out the ODD cage? also, if i take out the Front HDD and ODD cages for an AIO in the R5 will a 280mm rad fit and will my cpu be the same temp as the Define S?
thanks in advance for your help
