Ok Folks, I definitely need your insight on this. Per my other thread (symbolic links, ...... etc) current right here ..... I was attempting to re-define the location of my Pictures folder from a secondary data drive back to my home directory. Not quite sure what happened, but either I screwed up syntax, or windows got confused, but ..... what I ended up with is effectively my entire user directory, which should be at "c:\users\username" being now placed in a directory "c:\users\Pictures", and the aforementioned Pictures special directory now being located at "c:\users\Pictures\Pictures". And, somehow, the higher level "pictures" directory (c:\users\pictures) is actually designated as the special folder .... as when I right click on it it comes up with the option to change the location. all the data is there, and sure enough, when I check %userprofile% all of my usual home directory contents are now in the c:\users\pictures location.....
I suppose what I did wrong is that when I specified the change in location for the pictures location, I gave a path c:\users\username (assuming windows would create the sub folder "pictures" , when I guess I should have pre-created a folder with name and path c:\users\username\Pictures ????
How do I get out of this??????? One of the options when I right click on c:\users\pictures is "restore default". If I do this, will all get put back in place, or will things just get more hosed up. or ..... is there a more reliable/elegant way of re-establishing the correct paths.
I'm not really at risk of loss of data (backups/backups/backups), I just would really rather avoid having to re-build the whole user profile......
