defrag big problems
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.win2000.file_system (More info?)
Hallo, I can't defrag my hard disk, but I have to,
since my laptop has become unbearably slow.
I start the defragger. Everything seems normal, but after 40-60 minutes
the program stops without complaining that anything was wrong,
yet the disk is not defragmented.
The picture below says it all. Yet I have almonst 50% of the disk free:
http://168.144.107.58/defrag.gif
I have also run a checkdisk, which took a looong time, but completed
with no error msg.
Any idea about what I am doing wrong?
thanks
Luca
What statistics is the built-in defragmenter providing about this drive?
The built-in defragmenter isn't exactly known for doing a good job. I would
suggest booting into Safe Mode and try defragmenting from there and see if
it helps. If it doesn't, I'd suggest looking into a a more rebust 3rd party
defragmenter.
- Greg/Raxco Software
Microsoft MVP - Windows File System
Disclaimer: I work for Raxco Software, the maker of PerfectDisk - a
commercial defrag utility, as a systems engineer in the support department.
Want to email me? Delete ntloader.
"luca" <passani@eunet.no> wrote in message
news:WtaJc.2352$kk5.90013@news4.tin.it...
> with no error msg.
> thanks
> Luca
here are the statistics. Does it tell you anything?
thanks
Luca
Volume OPENWAVE (C:):
Volume size = 19,069 MB
Cluster size = 512 bytes
Used space = 9,867 MB
Free space = 9,201 MB
Percent free space = 48 %
Volume fragmentation
Total fragmentation = 14 %
File fragmentation = 28 %
Free space fragmentation = 0 %
File fragmentation
Total files = 78,641
Average file size = 165 KB
Total fragmented files = 39
Total excess fragments = 54,124
Average fragments per file = 1.68
Pagefile fragmentation
Pagefile size = 384 MB
Total fragments = 2
Directory fragmentation
Total directories = 7,318
Fragmented directories = 1
Excess directory fragments = 2
Master File Table (MFT) fragmentation
Total MFT size = 90,120 KB
MFT record count = 87,180
Percent MFT in use = 96 %
Total MFT fragments = 2
Luca
This isn't a very fragmented disk. You only have 39 files that are
fragmented (though, they appear to be very, very fragmented).
So you have a few problems:
1) The cluster size of 512bytes virtually guarantees that you will fragment
a lot. Basically any file >512 bytes has the potential to fragment. This
could also be the source of some of your perf issues since a given seek may
only result in a 512byte read instead of 4k (which is the normal default).
Unfortunately, there isn't a lot you can do at this point, since you would
need to re-format the partition to get a larger cluster size. If you ever
decide to recreate the partition, keep this in mind.
2) From the statistics, I would guess that the files that are fragmented are
very large. The page file isn't fragmented to any noticeable degree, nor is
the MFT so that's good news. I would recommend reviewing the defrag report
and looking at the files that are fragmented. There are defrag apps out
(some are free) that will defrag a single file/directory at a time. That
may work better for you.
The bundled defrag utility basically only defrags a file if there is enough
contiguous space to do so. If there isn't then it skips the file. That is
probably why it just stops after a while.
Pat
"luca" <passani_remove@tin.it> wrote in message
news:%qeJc.2600$OR2.93169@news3.tin.it...
> thanks
> Luca
> File fragmentation
> Total fragments = 2
> Luca
Greg, I downloaded the evaluation copy of diskperfect and
it did the job. Thanks a lot. I now realize what piece of s*#%
the standard win2k defragmenter is.
I am writing an email to the IT guys in my company recommending them
to take a serious look at this tool to manage PCs in the whole company.
Best
Luca
> defragmenter.
