Dell 5520 Won't Power On
sparker781
246
So from the title, I was attempting to flash the BIOS and it froze. So now when I power it on, it doesn't turn on just the fan spinning for a few, the power button lights up, then the 3 lights on the side flash like normal then it turns off. I have swapped the RAM out, took the battery out and still nothing. Would it help if I swap the Hard Drive out?
Ive read aboht similar issues with this model laptop and none of tbebe suggestions help
Thanks
I can't do that with a thumb drive?
You can try it, but if the bios is damaged enough that it won't boot to recognise the thumb drive then nothing will happen.
