[SOLVED] DELL 7573 battery replace guide
Feb 15, 2022
Hi i have a dell 7573 2 in 1, it has come with a 56wh battery internally. now i need to replace the battery is it okay if i go with a 42wh battery according to its parts manual guide? what will be the effect to get lower wh battery from the existance?
If both batteries were new, the 42wh battery would last about 75% as long as the 56wh battery.
If the 56wh battery was new and lasted 100 min, the 42wh would last 75 min.
Since the existing 56wh battery is OLD, they might last about the same or the new battery might last a little longer.
Hope that helps.
Hope that helps.
Reactions: Crunchbag
