Dell 8400 System with Dell 17" Flat Pannel and Dell Pri
damian_i15
FOR SALE(DELL 8400 PC WITH ACCESSORIES, DELL 17" FLAT PANEL MONITOR AND DELL ALL-IN-ONE PRINTER) ALL ITEMS UNDER WARRANTY. SYSTEM HAS ONLY 5 MONTHS OF USE BUT IS IN BRAND NEW CONDITIONS.
FEATURES:Dell Dimension 8400 computer with a Dell 17" Flat Pannel Display Monitor and a Dell 942 All-in-One Photo Inkjet Printer. All items under warranty. This is a performance PC that easily handles everything from basic applications to advanced digital video production. Includes graphics and memory to easily handle intense graphics, gaming and multi-media plus room to expand for future computing demands.
HARDWARE:
Dell Dimesion 8400
Description: Dimension 8400 Desktop (3.2GHz Pentium 4, 512MB, 80GB, DVD, DVD/RW, Windows XP)
Manufacturer: Dell
Processor
Processor Class: Intel Pentium 4 Processor w/ HT Technology
Processor Speed: 3.2 GHz
Number of Installed Processors: 1
Memory
Installed Memory: 512 MB
Max System Memory: 4 GB
Memory Technology: DDR-SDRAM
Memory Socket: DIMM
System
System Chipset: Intel 925X Express Chipset
Bus Speed: 800 MHz
Cache Size: 1 MB
Drive Controllers: IDE (ATA/EIDE/ATAPI), Serial ATA
Interface Type: Audio - Line In (1/8" Mini), Audio - Line Out (1/8" Mini), Keyboard - 6 pin mini-DIN (PS/2), Mouse - 6 pin mini-DIN (PS/2), Parallel - 25 pin D-shell (IEEE 1284A), Serial
- 9 pin D-shell (EIA 574/232), Serial ATA - 7 pin, USB - Universal Serial Bus 2.0, Video - 15 pin High-Density D-shell (VGA), Video - 29 pin DVI-I, Video - 4 pin mini-DIN (S-Video)
Number of PCI Slots: 3
Number of PCI-Express x1 Slots: 1
Number of PCI-Express x16 Slots: 1
Storage
Included Drives: DVD-ROM, Hard Drive
Hard Drive Capacity: 80 GB
DVD-ROM Read Speed: 16 X
DVD/+-RW
Features
Included Devices: Keyboard, Mouse
Multimedia
Video Integration: Card
Video Bus: PCI Express x16
Video Chipset: ATI RADEON X300 SE
Installed Video Memory: 128 MB
Sound Support: Integrated 5.1 Channel Audio
Modem / Networking
Included Network Card: Ethernet (10/100 Mbps), Gigabit Ethernet (1000 Mbps)
Modem Type: Data/FAX
Modem Speed: 56 Kbps
Software
Operating System: Microsoft Windows XP
Case
Chassis Style: Tower (Midsize)
Chassis Color: Black, Grey
Number of Externally Accessible 3.5 Bays: 2
Number of Externally Accessible 5.25 Bays: 2
Number of Internal Bays 3.5: 2
Height: 16.7 in
Width: 7.1 in
Depth: 17.6 in
Dell 942 All-In-One Printer
Description: 942 All-in-One Photo Inkjet Printer (19 PPM, 4800x1200 DPI, Color, PC)
Manufacturer: Dell
Printing
Functions: Copier, Printer, Scanner
Printer Type: All-in-One, Color Inkjet, Photo
Ink Color System: 6 Color (C,c,M,m,Y,K)
Color Horizontal Resolution: 4800 cpi
Color Vertical Resolution: 1200 dpi
Color Print Speed: 14 ppm
Black and White Horizontal Resolution: 4800 dpi
Black and White Vertical Resolution: 1200 dpi
Black and White Print Speed: 19 ppm
Media Handling
Paper Handling Support: Card Stock, Envelopes, Hagaki, Labels, Paper (Standard Cut Sheet), Photo Paper, Transparencies
Media Sizes Accepted: Envelope - B5 (176mm x 250mm), Envelope - C5 (162mm x 229mm), Envelope - C6 (114mm x 162mm), Envelope - DL (110mm x 220mm), Envelope - US #
10 (4.125" x 9.5"), Envelope - US # 7-3/4 (3.875" x 7.5"), Envelope - US # 9 (3.875" x 8.9"), Sheet - 4" x 6", Sheet - A2 (420mm x 594mm), Sheet - A4 (210mm x 297mm), Sheet - A5
(148mm x 210mm), Sheet - A6 (105mm x 148mm), Sheet - B5 (176mm x 250mm), Sheet - US 3" x 5", Sheet - US Legal (8.5" x 14"), Sheet - US Letter (8.5" x 11")
Min Paper Size Width: 3 in
Min Paper Size Height: 5 in
Max Paper Size Width: 8.5 in
Max Paper Size Height: 17 in
Standard Input Sheet Capacity: 100
Max Sheet Capacity: 100
General
General Features: Borderless Printing, Photo LCD Display, PictBridge Compatible
Interface Type: USB - 4-pin Universal Serial Bus
Slots: CompactFlash, Memory Stick, Memory Stick PRO, MultiMedia Card (MMC), SD Card, SmartMedia, xD-Picture Card
System Type: PC
Copying
Black and White Copy Speed: 19 ppm
Color Copy Speed: 10 ppm
Max Enlargement: 400 %
Max Reduction: 25 %
Scanning
Max Scan Resolution: 19200 x 19200
Internal Scan Depth: 281.5 Trillion Colors (48-bit)
Dimensions
Height: 11.4 in
Width: 17.2 in
Depth: 17.5 in
Weight: 10 lbs
Description: E173FP Black 17" LCD Monitor (17", 1280x1024, .264mm, PC)
Manufacturer: Dell
Display Panel
Diagonal Size: 17 in
Viewable Size: 17 in
Aspect Ratio: 4:3 (Standard)
Resolution: 1280 x 1024 (SXGA)
Contrast Ratio: 450:1
Brightness: 250 cd/m2
Pitch: 0.264 mm
Horizontal Viewing Angle: 140 degrees
Vertical Viewing Angle: 120 degrees
Interface
Interface Type: Video - 15 pin High-Density D-shell (VGA)
Interface: Analog
Other Features
Monitor Color: Black
Mounting: Desktop
Included Devices: Monitor Stand
System Type: PC
Dimensions
Height: 15.9 in
Width: 14.9 in
Depth: 5.5 in
Weight: 11.74 lbs
http://www.pcoverhaul.net/ebay/dell/main_small.jpg
http://www.pcoverhaul.net/ebay/dell/main2_small.jpg
http://www.pcoverhaul.net/ebay/dell/03_small.jpg
More images and videos available upon request
Please feel free to contact me at damian@pcoverhaul.net or http://www.pcoverhaul.net our website for more contact info.
damian_i15
Im asking 850.00 for the pc system
P.S I also have 512 MB SDRAM Memory and I also have a SANDISK SDWCFB128768 WIRELESS COMPACTFLASH CARD 128MB
SanDisk¦s Connect Plus 128MB + Wi-Fi CompactFlash card combines flash memory and wireless communications into a single card giving PDA and notebook users, the freedom to quickly transmit and receive data, images and music from thousands of hotspots worldwide.
Advanced Features:
Up to 11 Mbps High Speed Data Transfer Rate
Free PC Card Adapter for Laptops
Battery optimized for lowest power and highest performance
Powerful and easy to use security feature makes WEP encryption easy
Extends the memory and brings new functionality to the device
Single slot solution - can be used as memory card or
Wi-Fi card to store and move files
OS support for:
Laptops - ME, 2000, XP
PDA - PocketPC 2002, PocketPC 2003
Asking - 30.00
http://dts.ystoretools.com/1495/images/full/sdwcfb128768.jpg
