Dell inspiron 620 power supply.
w2sl
11
Does anyone know a power supply that I can buy to upgrade my inspation 620 305 watt power supply with? I would need a stock number and not just a brand name. I dont care the brand.thanks
seeing how you have the mini tower it will be very difficult to find a good higher wattage power supply to fit in that case.
if you have the standard desktop case, you should be able to put any standard ATX power supply in that case. Which do you have?
There are two different Dell Inspiron 620 models. The Inspiron 620 and 620s desktops.
The Inspiron 620 has a Mini Tower Micro ATX form factor and a standard ATX12V 300 Watt Power Supply.
The Inspiron 620s has a Slim Tower and a 250 Watt TFX12V Power Supply.
I've seen an Antec NEO ECO 620W PSU installed in the Inspiron 620 Mini Tower with no problem.
Are you planning a graphics card upgrade? If you are, please specify the graphics card that you are planning to use. This information is needed to determine the appropriate power supply capacity needed to properly power the system.
What is your budget range?
