Okay, so I've been kicking around the idea of building a sleeper PC for a while. I've been doing some research, and from what I've read, the Optiplex 390 uses a Micro ATX motherboard and a full ATX power supply. This makes getting new internals for the case fairly easy. However, there was something that I do not know how to address; the front IO panel for the case. To keep it looking as stock as possible, I'd like to re-use that IO panel rather than retrofitting a new one. And that means that I would have to use Dell's non-standard connector, which does not correspond to any motherboard on the aftermarket, at least to my knowledge. Should I try and find the pin out of the Dell cable, then pull the wires to put onto a standard USB 2.0 connector, with the audio going to its own header? Or will I have to cannibalize another case for its front panel connectors and mount them on the stock Dell panel? Or is there an aftermarket front panel replacement that I could just plug and play?
Also, as for the power switch, reset switch, and the power LED and HDD LED, I found a web page (https://www.bol.com/nl/p/moederbord...et-schakelaar-hdd-power-led/9200000092348565/ ) that looks like I could use the standard motherboard connectors for the power, reset switch, and LED's. I'd just have to yank the ones that are on the case and wire up the new ones, which I don't mind doing since it just requires some elbow grease and adhesive.
If anybody has had experience with this kind of thing, I would really appreciate some help in getting all of this sorted. Thanks in advance!
