Dell Optiplex GX280 low battery
Thanx for your reply
I"ll try to find a new battery. What's an SMT? My model is called a Small Form Factor and is only 2 years old. I could not find a spec in the website you provided for the battery. I'll check in my local repair store. thanx again
Paul
Just look on the motherboard, and check for the CR # on the battery. The battery is below the RAM slots towards the bottom of the board. The average battery is a CR2032. This can be bought almost anywhere - drug stores, Walmart, grocery stores, Radio Shack, etc.
i have the same problem on gx280, but i changed the battery, and the message remain..
"alert! System battery voltage is low"
plus, when i shutdown the system, after some time, the fan start himself and turn very quickly , and the card check components, without starting computer..
if i start computer, all remain normal, with the same message .
i tried 2 differents new battery, same thing..
strange no.??
