I just wanted to upgrade my dell precision T5400 workstation and got my self in a whole lot of trouble!
Motherboard: 0RW203
PSU: GM869 or H875E-00
Psu wire Harness: YN945
I wanted to upgrade my gpu to Sapphire r9 280x dual-x. It requires 1x6(75w) pin and 1x8(150w) pin power connectors.
These are the PSU's (850W) outpouts
P1 - 24pin ATX Power
P2 - 20pin ATX Power
P3 - 12pin Power
P4 - None
P5 - 6pin Power (2x3)
P6 - 6pin Power (2x3)
3 x Sata Connectors
1 x 4pin Molex ( +1 x 4pin Floppy on the same cable)
Both 24pin and 20pin are connected to the motherboard and if I'm not mistaken the 20pin is utilized for fan power.
My problem is that there are only 2x6 pin connectors and only 1x4 pin-molex (even if I wanted to use two molex and an adapter to produce 8 pin conntector). I don't want to use a 6pin to 8 pin adapter since that equals to a lack of 75w.
There is a strange 12 pin socket that is currently connected to a sata power cable (2 sata plugs on the cable). My question is if I can (remove the sata cable and) connect on this 12 pin socket some kind of 8 pin adapter or even if I can retrofit something my self.
The wattage and amperage have to be the same as a regular 8 pin socket.
Just found the pinout. It's the P3
Thanks to Doramious for the pinout diagramm
PS: Please don't mention the ''get a new psu'' idea.
Motherboard: 0RW203
P3 - 12pin Power
P4 - None
3 x Sata Connectors
![dellh875e00psupinout.png](/proxy.php?image=http%3A%2F%2Fimageshack.us%2Fa%2Fimg202%2F6812%2Fdellh875e00psupinout.png&hash=3d1f2e033b47c828f01c31ac135d64be)
