Dell UP3017 30-inch 16:10 Professional Monitor Review
Hi,
I've seen loads of PC monitor tests, I've never seen a TV as PC Monitor test.
In 2009, I did first see a friend using a wall mounted TV as second monitor for his laptop.
TVs being cheaper, smarter and prettier than PC monitors, I've made the step to a 42" 3D capable Philips TV a few years ago.
I've never looked back !
Now with reasonnably priced 4K and even better looks, TVs might be even more attractive. Don't you think ?
Regards,
Claude
Because mostly they look like crap for some reason close up, i have a 40" 4K TV above my monitor meaning it has 110ppi, but i prefer my IPS 34" 3440x1440 (110ppi as the tv) monitor that has way better image at close range than the TV, at 2-3m you can`t really tell them apart.
Sure if you have a big room and wall mounting placement is not an issue.
Resolution is another thing, only the popular resolutions are available for TVs which is 1080p and the 4K, nothing in between.
Next, they don't have adaptive sync.
If you ask me though, I will have to wait for any monitor with a 120 Hz and 4K interface
If this monitor ever goes down to 600$, then I'll for sure buy one. I understand that this is for professionals, and for them it might be worth it, but at 1249$ MSRP, this monitor isn't the best value.
Recently Dell had a 25% off sale. I'm sure it will come around again.
I'm rocking an old Dell 16:10 at the moment (1920x1200) and the reason I haven't "upgraded" is primarily due to it feeling like a DOWNGRADE dropping to 16:9. The extra pixels at the bottom when you're doing 16:9 video editing, especially, is pure gold. Shame this screen is relatively expensive though. Would love to see this same resolution in a 27".
Max Resolution & Refresh
2560x1600 @ 60Hz
$1068.24
Aw, man... $1k for a 30" monitor that's not even 4k? No thanks.
And where's the @#(^%&*$ OLED monitor they showed way back at CES? Last I heard, it was supposed to come out in August. Did the release get pushed back again?
Not like I was going to buy one, but I want an OLED monitor, so they'd better start coming out.
It's actually a decent price if you take a look at pcpartpicker's listings. They don't list every monitor for sure but yes, $1000 for a 30" ips panel at 16:10/2560x1600. Others from nec and hp range from $1200-2000.
There are cheaper 32" 4k monitors like the BenQ BL3201PH but it's not really a professional monitor either. The colors aren't said to be the best, it's stuck with the srgb color space (no adobe options), contrast isn't the best. If doing basic tasks or cad work it's probably fine, for those doing design which will go to print, not so much. Features cost money and could be worth it if someone needs them. If not needed then it's overkill and ends up costing more.
If all someone wants is a giant tn panel they're out there for less money. Dell's done pretty well for themselves with the ultrasharp's for the most part.
I have long preferred 16x10 having had (and still have) a 22" 1680x1050 Samsung and a 26" 1920x1200 Samsung. That extra height was great for flight simming and sim racing having extra virtual cockpit instrument reading capability.
When making the jump to 2560x1440 with a 27" Dell three years ago I was missing that extra height, but the increased resolution and screen real estate more than made up for it. Honestly I am surprised panel makers are still making this aspect ratio since the manufacturing economy of scale favors 16:9 panels both for PC monitors and obviously for TVs. Considering Dell has had 30" 2560x1600 monitors for years and the fact that they are still over $1,000 proves it.
Lets face it this monitor is for business and not gaming.. Dell sells tons of monitors.. almost every office I have been had almost all double Dell's on each desk..
While it is their "professional" line the fact that it has a 6ms response panel means it would be good gaming panel as well. It's the exact same response as my 27" Dell 1440p.
About the only thing I will say negative about Dell's upper tier IPS panels is that they do not overclock well. I got mine up to 80Hz but there was severe stuttering problems with V-sync on locking FPS at 80 in games. I never had that problem on my cheap LG-made 27" Crossover 1440p knock off (Apple Thunderbolt reject).
I wish they also compared it to the U3014 to see if there is any noticeable improvements. I have 3 U3014 and just curious what has changed without having to check old reviews.
And another thing about TVs being bad as computer monitors, the input lag, it`s terrible, on PC we have monitors that can almost go on par with CRT but the TVs are terrible for gaming. Don`t mistake response time 1ms - 5ms to input lag :)
