[SOLVED] Dell vostro 200 does not power on
Jun 20, 2019
4
I'm stumped with this pc. When I press the power button, it does nothing and does not light up in the front. I have already replaced the mobo with a new one, and still nothing, but the amber led lights up on it. I have a power supply tester that showed the psu to be good as far as I know and here are the results just to be sure.
+5v: 5.2
+12v1: 12.3
+3.3v: 3.5
-12v: 12.6
+12v2: 12.3
5vsb: 4.9
Pg: 170 ms
There are three leds in the tester as well for +3.3, +12, +5 and all of them were lit up green.
Any suggestions?
Most PSU 'testers' merely turn on the PSU and read it's outputs under a zero load condition....(which is not really a 'tester' at all...)
You need a known good PSU before branching outward... (often, a dead BIOS battery can really screw things up as well...; borrow one to rule that out)
When swapping a PSU, if modular, do not use old modular cables with new PSU, the pinouts are usually different leading to unknowing souls burning up assorted components at first power on attempt...
I ruled out the BIOS battery, then I ordered a new psu because I don't have a spare one and maybe that will work. Once I get the psu, which isn't modular, then I'll post back here if it works or not.
Reactions: NightHawkRMX
Thanks for the help, the new psu did the job.
