Desktop beep sound.
gil_rodrigues16
79
Hey guys, so i just got this pc, and i have been using it for less then a month. But today when i tried to turn it on, it just made a beep sound and thats it. The cpu fan and case fans remain spinning. Same with gpu fans. It just makes a single beep sound that repeats after 5-10 minutes. My mobo is ASRock H97 Anniversary if that helps. I already disconnected all the cables including monitors and plugged them back on, but still nothing. Can u guys help me ? Thanks, i would really realy aprreciate it. Regards, Gil.
*UPDATE*: I've searched for the issue now and it seems that is an DRAM refresh failure. Hope this helps at annything.
Once again, thanks.
Well, that depends. Is it one short beep and that's it? Because that usually signifies a successful POST.
Perhaps you should look up the BIOS Beep codes for your specific mobo, it might mean something more.
EDIT:
Giving you the benefit of the doubt, if it really is a DRAM issue, a quick browse of the internet suggests jumping.
This is the instructions from the ASRock H97 Anniversary Manual I found on the internet. Please make sure this is actually your issue and solution before you follow the instructions below:
EDIT:
