Question Desktop freezing or rebooting - Kernel Power 41 (63), Bugcheckcode 278/281
May 4, 2020
Hi everyone. Ever since about a week ago, my prebuilt Alienware Desktop that i use for gaming has started being a nuisance.
Everything worked fine beforehand, but in the last couple days my desktop either suddenly has a freeze of death and i have to hard reboot it, or the desktop freezes and after a couple seconds auto-restarts. I've been trying to troubleshoot myself and found a couple useful threads, but was unable to resolve the issue at hand. Those threads seem to suggest graphics card driver issues or power supply issues.
The crashes seem to happen unrelated to whether or not a game is running or the runtime, sometimes i have a streak of no crashes at all for hours, and worst-case my PC crashes 6 times over the course of 30 minutes and 8 times a day. I share the room with a roommate who also uses his notebook for gaming.
What i've tried:
Rollback Graphics card driver in devmanager, completely uninstall and reinstall graphics card driver manually
Install all Windows updates
Run System File Checker
Uncheck "Perform automatic reboot"
Monitor GPU heat (idling around 40, going to 80 when playing games)
My computer:
pre-built Alienware Area-51 R2 x64
Intel (R) Core(TM) i7-6900k CPU @ 3.20 GHz [01]: Intel64 Family 6 Model 79 Stepping 1 GenuineIntel ~3193 MHz
NVIDIA GeForce GTX 1080
Win10 Home 64bit 10.0, Build 18362
64gb RAM
BIOS Alienware A14, 02.07.2018
Power Supply Dell D850EF-00 850W N1WJD Power Supply
DirectX12 installed
Here's what the eventlog says after a crash:
- System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331c3b3a-2005-44c2-ac5e-77220c37d6b4}
EventID 41
Version 6
Level 1
Task 63
Opcode 0
Keywords 0x8000400000000002
- TimeCreated
[ SystemTime] 2020-05-04T15:33:45.994308100Z
EventRecordID 18281
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer DESKTOP-MM0EKKD
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 278
BugcheckParameter1 0xffff8682a682f460
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
This is what the tool "WhoCrashed" gathers from the Memory.dmp
On Mon 04.05.2020 17:04:47 your computer crashed or a problem was reported
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: Unknown (0xFFFFA28D12BC3E70)
Bugcheck code: 0x119 (0x2, 0xFFFFFFFFC000000D, 0xFFFFDD869D232920, 0xFFFFA28D12BC3E70)
Error: VIDEO_SCHEDULER_INTERNAL_ERROR
Bug check description: This indicates that the video scheduler has detected a fatal violation.
A third party driver was identified as the probable root cause of this system error.
Google query: VIDEO_SCHEDULER_INTERNAL_ERROR
On Thu 30.04.2020 20:09:59 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\043020-9593-01.dmp
This was probably caused by the following module: watchdog.sys (watchdog+0x41A0)
Bugcheck code: 0x119 (0x2, 0xFFFFFFFFC000000D, 0xFFFFFC0D2CC07920, 0xFFFF9D0156830650)
file path: C:\Windows\system32\drivers\watchdog.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Watchdog Driver
The crash took place in a Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
