Iv been a long time follower of these forums and Iv browsed them anytime I had questions and they’ve helped many times with many things. Up until now I was able to find the answers to all my questions. This is actually the first time I’ve made an account and this will be my first posting so I apologize if it’s not in the correct place. However with this particular problem I really can’t find anything anywhere.
So basically I have overhauled this entire machine and done a lot of custom work to it and one of the upgrades I did was going from the original 8gb ram to the 16gb Corsair ram I have listed below.
Now what Iv noticed in the process of that upgrade was that my pc reports everything about the ram correctly (speed, size, brand, etc) however it doesn’t report the correct form factor for the ram. It is a desktop so obv the form factor is DIMM. That’s what the modules are, however whenever I look on task manager it shows the modules form factor as SODIMM (laptop memory) which we know can’t be true. So I thought maybe it was just a reporting issue on task managers end so I check in command prompt what the pc thought the memory was. And again it reports it as SODIMM. Now this may just be a reporting/recognizing issue that has no effect on the pc at all. But it raises concern for me that my pc thinks the ram is something that it’s not, and it makes me think that there might be some sort of performance limiting effect caused by the pc thinking it has different form factor ram then it actually does. Maybe the OS manages the different rams differently or is more power conservative with laptop ram. I really don’t know and couldn’t say if the different form factors are handled differently or if there is any difference/performance effect at all. But Id hate to find out that this issue is holding the pc performance back in some weird way.
I’d like to get the reporting issue fixed so that it reports the correct form factor if possible. If that’s not possible I would like to verify that there is no effect on performance because of this issue. I just wanna make sure that everything is working as it should be and that there is no effect on pc or ram performance.
The desktop is a dell xps 8300 running on windows 10 (originally a windows 7 machine) that was built in 2011 and since then has been completely overhauled. Currently it is configured as follows:
ONLY HARDWARE THAT IS ORIGINAL IS THE MOBO, CPU AND CPU COOLER
OEM dell motherboard oy2mrg
OEM I7-2600 3.4ghz 4 core 8 thread (thermal paste replaced with noctua)
16gb DRR3 Corsair vengeance 2x8gb (1600mhz cl9) running @ 1333mhz cl9
Asus Rog strix gtx 1060 “OC” 6gb running overclocked @ 2.1ghz clock and 9.2ghz memory
Samsung 860 evo 1 tb on sata 6gb/s (main OS)
WD black 4 tb on sata 6gb/s (backups)
WD black 2 tb on sata 3gb/s (libraries/data)
Corsair rm850x 850w psu
Usb 3.0 pcie card and 3.5” usb 3.0 front panel
I also cut and installed 140mm front intake fan and 120mm side panel intake fan to fix the lack of airflow in this case. Originally it had just 80mm cpu fan and one 92mm exhaust.
All around I think the pc runs pretty damn good but I would love to get the form factor sorted out and reported correctly if possible. If not possible to get correct and it has no effect on pc performance then I won’t worry about it I guess. i can add photos of anything when I get home from work tonight.
