Device Manager problem
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
Under "other devices" I have a question mark.
It shows also PCI CARD and PC MASS STORAGE CONTROLLER with a yellow question
mark.
What can I do to fix it ?
I use an ASUS motherboard
> mark.
I suggest you take a physical inventory of your system. What kinds of plug-in
cards does it have. You can also use Everest Home Edition to take inventory, but
it will make more sense if you have a general idea, already. Things like the
model number of your Asus board, and those for other things like cards. You may
even be able to identify which item is referred to by the "bangs" in Device
Manager by comparing with the Everest report.
Once you identify what the items are, then we can suggest the appropriate
methods for fixing this problem. Oh, and one other task you should perform: Go
into Safe Mode and thence into Device Manager, and review the entire list for
anything you recognize as no longer part of the system (old monitor or modem,
etc.) and also look for any items that are duplicated. Report back with a list
of these items, what items are duplicated and how many times. Also, if you know
what "Sections" the problem devices are in, please tell us.
Gary S. Terhune
MS-MVP Shell/User
"cpojano" <cpojano@discussions.microsoft.com> wrote in message
news:C3D92F3D-6F5B-4A0E-8CCC-FE76D17EB912@microsoft.com...
>> mark.
Do you have a add-on controller card installed? If so, you need to install
the drivers for it.
If not, you need to determine if it is a motherboard controller and install
the drivers for it.
Either way, if you do not have the disk/files to install, check the
manufacturers support site and download/install the drivers per their
instructions.
The best way to determine what is in conjunction with your machine is to
download the free Everest home:
http://www.lavalys.com/products.php?lang=en
Create a new folder named Everest and extract the contents of the download to
that folder.
Open the folder and double-click everest.exe to run the application.
If you are not sure what next step to take, other than downloading/installing
from the manufacturers support site.
Click the + next to Computer.
Click Summary.
On the menu bar click Report > Quick Report-Summary > Plain text.
Save to your desktop and close Everest.
Open the report on the desktop.
Delete everything from Debug on down to the bottom of the page and save.
Press CTRL+A to select all.
Press CTRL+C to copy and close out.
Open a response in this thread and press CTRL+V to paste.
Post the results in a response to this thread.
Brian A. Sesko { MS MVP_Shell/User }
Conflicts start where information lacks.
http://basconotw.mvps.org/
Suggested posting do's/don'ts: http://www.dts-l.org/goodpost.htm
How to ask a question: http://support.microsoft.com/kb/555375
news:EAD47418-2FE8-4DCE-A712-CB0E878B3E7E@microsoft.com...
> mark.
I would go to the Asus site and see what the motherboard assets are.
Tend to believe you have SATA, RAID, or an additional 3rd ide controller.
Just depends on the model.
Solution is to install the driver, may be on the mobo install CD. If not,
try the Asus website.
question
> > mark.
