Hello all,
I bought a DFI Lan Party UT NF4 Ultra mobo knowing that DFI's run somewhat more hot than the rest of the croud, but I was not sure how hot it was going to be. I recieved the mobo and it works great, but the temps are beginning to make me worry...I have it in a not cold, but also not warm room and it is in open air cooling (as in; both side panels are off) and it is posting temps of 42 - 45 degrees C when idol and 48 - 52 degrees C underload. It even hit a peak temp of 55 degrees C during Rainbow Six: lockdown, any input on this issue would be great, i. e. is it to hot / if so what can i do to lower it.
note: i have tested while OC'ing and not OC'ing and the temps are similar...maybe 1 degree C difference.
Thx for the help!
Antec NeoHE 550w PS
AMD Athlon 3700+ Sandy @ 2.8ghz (10x280) - "Arctic Freezer 64"
2gb (2x1gb) Patriot Performance mem (2-3-2-5)
ATI Original X1800XL - "Arctic Accelro X2"
Creative XF-I
(2x120gb WD SATA II HD's) - Raid 0
Thx for the help!
Antec NeoHE 550w PS
Creative XF-I
