Dial-up and dsl on same phone line
bzand
185
If this is not the correct catagory please direct me to the correct one. We currently have a dsl connection from verizon along with home phone from them. I want to try dial-up for the heck of it(its been a while) I found a free service from nocharge.com(I know its probaly not a good idea). To use it you get a number to dial. Say I set it all up and use the connection will I be able to use my homephone at the same time?(I'm aware of dialup and phone not working at same time) I thought maybe since its dialing a diffrent number than the phone it may work without tying it up?
Unless you are paying for two phone lines, you will not be able to two have outgoing calls simultaneously. Many setups have a single line running both a phone signal and DSL, which can coexist. Even if your setup has two lines, however, you will not be able to use the dedicated DSL line for calls.
