Did I make a big mistake by putting Silent Wings 2 fan on Hyper 212 Evo CPU heatsink
Yuki Core
173
So I just bought Be Quiet Silent Wings 2 120mm PWM fan for Cooler Master Hyper Evo 212 CPU heatsink.
I was researching for a fan very quiet that cools well, was deviating between Silent Wings 2 and Noctua, ended up with better looking, cheaper and quieter wings 2.
Now after a warm start, I stress tested my CPU(i5-3570k), and the temperatures didn't rise above 60*C. Which seems pretty nice, but what worries me is that after I purchased the fan, I noticed that it has quite low air pressure, which should be the first thing to look at when getting a heatsink fan, right? Should I get another fan, or is this one fine? Otherwise it's great, low noise level on full load, it's whisper quiet
Stock fan:
Fan Speed 2,000 RPM
Fan Airflow 82.9 CFM
Fan Air Pressure 2.7mm H2O
Be Quiet:
Fan speed 1500
Air flow 50.5 CFM
Air pressure 1.63 H2O
Since the fan sits in front of a heatsink it should be a static pressure model. Using a regular case fan it will impact the ability of the cooler some, but if you can keep the temps down with the new fan it should be ok.
Finding that "Be Quiet Pure Rock" has a 1.25 H2O fan and performs better than hyper 212 was relieving. Maybe it is a better heatsink, I don't know. I guess I should monitor the temps for some time, otherwise seems that it should be fine.
I kind of found the solution myself, but I honor the speed of your reply and short and straight to the point answer, thanks.
