[SOLVED] Difference between 3080ti models
Nov 13, 2021
5
So i just about the 3080ti gigabyte eagle pretty sure it’s the lowest brand the one without the overclock option, was wondering is there a major difference in performance based on winch sku model i picked up or is the gpu i have just as good as the others? Are the components pretty much the same or worse?
Thanks guys quite interested in the replies :)
rarely is there much of a difference. a few fps here and there but rarely worth the extra couple hundred unless you just have money to burn.
only real difference i have seen is with the cooling options. better cooling can run quieter but even that is out the window with these 300w+ gpu's. they all need such crazy cooling that none are really all that quiet anyway unless it is running on water.
IMO with power delivery and many other things you get what you pay for with these to an extent. Example I would rather have a EVGA FTW 3080ti vs a base model 3090.
Reactions: chinfu21
Reactions: chinfu21
Latest posts
