Question Difference between connecting to 1 and 2 sata cables to RGB controller for UNI FAN SL V2
Znn
Commendable
Aug 30, 2022
82
13
1,545
Im using 3 fans
the website for UNI FAN SL V2 recommends to connect its power connection cable that has 2 sata headers, to 2 different sata cables.
What would happen if I plugged it to a single sata cable?
here's my specs:
Psu: rm 1000x Gold 80 Plus
Motherboard: Asus Prime Z690-p Wifi Ddr4
Im using 3 fans
here's my specs:
Not a problem if you are using fewer than 12 fans or using white color often due to the added power requirements.
If you lack a spare motherboard header you can get a back USB2.0 slot to internal USB port adapter like THIS.
