Difference between Intel 8265NGW and Intel Intel 8265.NGWMG
Are they both compatible with PCIe?
The Intel site says the regular 8265 is compatible with PCIe:
https://ark.intel.com/products/94150/Intel-Dual-Band-Wireless-AC-8265
My current card is the 3165 and according to the Intel website, this uses a PCIe slot.
I am a bit confused when certain Intel cards say, "M.2: PCIe, USB"
For example, the next card up in spec, the 9260, says "M.2: PCIe, USB"
https://ark.intel.com/products/99445/Intel-Wireless-AC-9260
Presumably that isn't compatible with PCIe?
I got the 8265NGWMG
It arrived today and I installed it
Works fine
It seems to have really fixed the shitty signal I got from my old 3165
Am I correct in the way I installed it?
I swapped the 2 cable with the 1 cable, such that the 2 is plugging into the 1 slot, and visa versa
That's how my old 3165 was installed when I first opened up my laptop, with the cables swapped around
