Difference between RGB Fans and LED Fans(If there is any)
blackd51th
Commendable
Oct 8, 2016
86
Hi All,
I know this maybe the stupidest question ever but I like to know the difference between RGB case fans and LED case fans. I want to get a look like the image below from a Coolermaster Masterbox Lite 5 Casing which doesn't have RGB fans pre-installed. So I want to get some fans for that and I'm confused whether to buy RGB fans or LED fans.(will be using a Asus Z270F motherboard with Aura Sync so I want to hookup the front fans to that if possible)
index.php
Hi there,
Thanks alot for answering so quickly. So if I were to buy some fans online form ebay or amazon, I should search for 'RGB LED Fans' right? Also do kind of RGB fans support Aura Sync or do the fans have to come from a known manufacturer like 'Coolermaster' or 'Corsair'?
