[SOLVED] Difference sapphire tri x r9 290x oc and sapphire tri-x r9 290x
May 2, 2020
8
What is the difference between the sapphire tri x r9 290x oc and r9 290x sapphire tri x.
Are they the same card pcb wise.
If so do they support Kraken G12 GPU cooler and do I need a copper shim?
The only difference is a 30Mhz clock speed. They are the same card and same PCB.
Spelling. That is the difference in what you posted.
Now, if you have MODEL NUMBERS to compare, that would be different. Based on naming, there would be no difference and chances are good that ANY differences between two R9 290X Tri-X cards will be minimal. The whole point of Tri-X is that is is a specific type of cooler. There IS a 290x Tri-X OC that comes with a higher factory overclock out of the box.
