Hello,
I have a prebuilt dell in a pretty small case with a 460 W power source, it has very solid specs, but is missing in the gpu power currently with a HD 6450. I did some measurements and decided it will be unable to hold a 9 inch card.
So i have decided on the 6 inch low power demand HD 6670, I realize their are better cards but they will not fit and this will increase my performance by alot.
That being said I am having trouble deciding what maker of the card I want,
The two im really looking at are Asus
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121442
and the xfx
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150576
I am not too knowledgeable on cards and noticed the difference to be ddr3 with higher mhz and ddr5 with lower mhz.
Which do you guys think is better?
and the xfx
