G
Guest
Guest
Archived from groups: alt.comp.periphs.dcameras,rec.photo.digital,rec.photo.equipment.35mm,rec.photo.film+labs,rec.photo.darkroom (More info?)
Colin D wrote:
> BillyJoeJimBob wrote:
>>Tom Phillips wrote:
>>>Quote: "the pixel size of a highly sensitive emulsion layer is
>>>assumed to be 100 square micrometers on the basis of the fact
>>>that a color film with an ISO 400 sensitivity and 135 format
>>>contains 24 million pixels."
>>Typical 135 format film measures 36x24 mm, for a total imaging area
>>of 864 square mm, or 864,000,000 square microns. Dividing this by
>>the quoted pixel size above yields 8,640,000 "pixels" on the 135
>>format film. I have no idea how the authors of that quote came up
>>with 24 million, which at first glance appears to be too large by
>>nearly a factor of three. Perhaps the authors assume some degree of
>>overlap between "pixels" on the emulsion layer?
>>BJJB
> Because with 8-bit depth, it takes 24 bits, or three bytes per pixel,
> not one as you assume in your calculations.
My calculations have nothing at all to do with bytes, nor does the
original quoted text. We're talking "pixels", as in "spatially
separated discrete imaging sensor elements". The authors of the
original quote did not state anything regarding "24 million bytes"
of data contained in 135 format film. I made no statement regarding
8 million bytes of data.
In the context of the original quote, bytes are irrelevant.
Even if we were to consider the possibility that the authors were
speaking of RGB color, the term "emulsion layer" implies a single
layer (i.e. a single color channel), not three. There's no "three"
to multiply by in a single emulsion layer.
BJJB
>>BJJB
BJJB
