Hello
So I am working on trouble shooting a computer running XP Pro on a server grade motherboard. Right now the computer has a Creative SB1040 sound card and will not produce a 5.1 signal out of the optical port. The speaker set is outputting to is a Samsung HTZ320 dvd player/receiver (5.1) but can only seem to get 2.1 out (R/L/Sub).
I was thinking that maybe the card is not capable of encoding proper formats for 5.1 so I have tried to swap out the card for a Creative SB X-Fi Titanium card which I know outputs 5.1. This resulted in still only a 2.1 output to the speakers.
I then tried to swap out the Samsung front end for another 5.1 HT system which I know to be able to output 5.1; only to yet again hear 2.1 sound. I spent a few hours messing with the creative audio control panel and the windows audio settings to no avail. I, just for s-and-g's hooked up the two receivers in tandem for a 4.1 system (analog connections) and was successful. Also, I tired to install the active Dolby/DTS encoder software, found through searching around, but the installer told me that the program wants at least Vista in order to install.
The second receiver has a little display on the front displaying what type of encoding is being used for the optical input and it shows Linear pulse-code modulation (LPCM) which is most commonly found with a 2.1 output but is capable of encoding 8 channels (7.1).
Does anyone have any ideas for my problem? (other than getting a new computer)
Thanks for your input
