Digiutal Audio Output
MrFSS
If I plug a digital audio cable into the port on my Panasonic HD set, will it cause the sound to the set speakers to be shut off. In other words, I need to use a digital audio cable for a wireless headphones setup, but still want the normal sound from the speakers. Thanks!!
In most cases no, it will not shut the speakers off. You will be able to use both the digital audio cable and listen through the TV speakers.
The speakers are normally turned off through the TV's menu.
Thanks - what I wanted to hear!
