Diplsay setting only showing 60 hz option but monitor and intel setting showing 120 hz.
volt2016
My monitor says 120 hz so does intel graphic setting but windows display setting says only shows 60 hz option.
Hello,
If you set the refresh rate within the gpu driver to 60 then it could override windows reading.
What is your laptop/pc build and what is your windows version?
Regards
I have a Msi gl62m hook up to a Aoc g2460pf thru a displayport with windows 10, thank you for the reply.
