Hello, due to the usual wear and tear, my front audio jack has been knocked loose and no longer works. The problem is that due to the nature of its breaking, it now thinks there is always something plugged into it which in turn disables my rear audio jack. Therefor I no longer have any sound at all.
My question being is how do I turn off the whole front panel audio altogether so I can use my rear audio?
I have a Gigabyte GA-EP35-DS3L ver 1.0
To save you some time, I got the manual for it here
http://www.gigabyte.us/Support/Motherboard/Manual_Model.aspx?ProductID=2778&ver=#anchor_os
I have heard that I can disable it by bridging some of the F_AUDIO pins but I am not sure if that is true and if so which pins to bridge but I went and got some pin connectors anyway just in case.
I have already tried all the Realtek stuff like "Disable Front Panel Jack Detection" but since this problem is due to a broken jack, it didn't work.
Thank you for your time.
