Hello all,
I started a thread earlier on how to setup patch panel in small home networking setting and received lots of people recommending patch panel for good cable organization and different ideas on how to make the connections.
But are there any disadvantages of having patch panel in home network setup esp. for someone like me who will not touch and modify the network in the future once first setup?
I can think of few:
1.add extra cost to equipment setup because I need to buy patch panel and frame that panel can mount on
What do you guys think? Any disadvantages?
I can think of few:
- add another layer of complexity to the network. Instead of ethernet cable connect directly to switch, patch cables are needed to connect from panel to switch. As result, more cost is added to buy patch panel and add another point of error at patch panel keystone jack + RJ45 jack.
- If the cable are stranded type, then more difficult to finish them in keystone jack on patch panel
