Hey everyone. Been awhile since I've posted here, but I'm finally at my wits end with this issue.
Quick explanation of the setup:
External Fios box passing in ethernet to lower floor
-> Netgear R6700
-> ethernet passes along ceiling to living room above
-> panel in LR -> ethernet to my desktop
Occasionally, my connection to the living room drops completely thinking there's nothing plugged in ("No Connection"). Been happening for a number of months. When it happens and how long it lasts is non-deterministic. Sometimes, messing with the panel seems to help, but that may be pure coincidence. Last night, the connection went out and no amount of messing seemed to help (I then went to bed in frustration).
For other debugging info:
I originally was using a switch in the basement and had the Netgear in the living room for better wifi, but this issue popping up made it painful since wifi would then drop. There are other in-wall cat lines, but I haven't tried them since I haven't scoured to see where they come out.
I think I'm at the point where I should just rip out the line to the living room and install a new CAT 6 line, but the intermittent behavior (I swear there was a time when it happened only on Friday nights....or I'm going crazy) of this issue has me absolutely stumped. I figured a bad cable would just be dead, not random levels of dropping out.
Is there anything else obvious I should be checking here or other recommendations besides just ripping it out?
-> Netgear R6700
Router maintains a connection (wireless keeps running)
Connecting a separate ethernet & computer to the panel stays disconnected
Swapped ports on the router -> nothing
Connected laptop & ethernet directly to R6700 and its fine
