Question disk conversion problem
Feb 1, 2022
I'm having trouble converting an mbr disk to gpt in the command line. I'm positive I have typed in the correct command but when I hit enter all it gives me is a list of switches for the command and does not execute it.
I have tried all that. mbr2gpt.exe does nothing and the command line option with the /allowFullOs switch only returns a list of switches that can be used with the covert command. There is no option in disk management right click menu
Yes I want to keep the whole thing. That's why the /allowfullos switch. I have done this on my computer which is exactly the same and it worked without issue. I get it that the bios needs to be changed after the conversion as well. Am I missing something that it only returns a list of switches to use the command?
