Disk Management help
saiyansantos94
C drive, disk 1 partition 1, and disk 1 partition 2 are the only things showing up. How do I get my other drives to show up?
My mobo is an MSI 970 GAMING (MS-7693) and my ssd and drive is connected to the sata ports. The drives show in the bios but after i reinstalled windows 10, only C drives show up in disk managment. I'm thinking I might have deleted them during the reinstall.
Did you reload your motherboard drivers after the OS reinstall? After you do that, make sure that the SATA cable (flat, 1/4" wide) and power cable (flat "L" shaped connector about 1" wide) are connected to each drive. Restart the computer and check disk manager again. If disk manager still doesn't "see" them, download the free version of AOMEI Partition Assistant (https://www.aomeitech.com/pa/standard.html) and see if it can see the drives.
I now see Disk 1 and Disk 2 after downloading that app. https://imageshack.com/a/img924/3420/9vUoje.jpg This is what shows up now. Previously this is what showed up in disk management https://imageshack.com/a/img924/1799/yvvBVH.jpg
