If I have DP and DVI monitors connected, my PC is unable to turn off the DP one, and instead gives it a black output signal
Nvidia customer support was a bit useless on this one, it got to the point of "try install a 2+ year old driver" and I kinda gave up. I did attempt searching for others with the issue but didn't find much info.
My primary monitor is connected with DisplayPort, and my second monitor is connected with DVI. If I hit the screen timeout limit of windows, the second monitor turns itself off, and while the primary monitor also turns off, within a second it turns on again and displays a black image indicating it's getting a signal from the GPU. If I unplug the DVI monitor, then the issue goes away.
I've used the DDU to do a fresh install of the drivers, but it hasn't made any difference, so I've just set my screen saver to run for an hour since I won't get any power savings
I wasn't sure whether to post in monitors or gpus, but I would appreciate a bit of help if anyone has any ideas, it's quite annoying.
My CPU is the Ryzen 2700x and GPU is the GTX 1070Ti. There's nothing fancy in my setup, the monitors are just plugged directly into the GPU.
