Question Display Port not working on Benq XL2411P
Scotchy
5
Hi,
I recently bought my first 144hz monitor (Benq XL2411P), but getting error of no signal. I'm aware that it requires DP or DVI-D to get 144hz.
Firstly it is connected to the GPU (GTX970). I have tested HDMI and DVI monitor connections(Not 144hz version) and it works.
I believed my DP was not working on my GPU but tested with HDMI (Monitor) to DP (PC) and that works.
I also tested on another computer that uses GTX 960 with a DP to DP and works fine reading it at 144hz.
I additionally bought another DP cable to see if it works and doesn't.
I'm somewhat baffled why it wont work on this PC but can work on others. I may be missing something silly but really scratching my brain.
Any help/advice would be really appreciated.
*Edit - I also have switched which cable inputs are selected through the monitor menus
Update: I found out that because I have my Wacom Cintiq connected to DVI port it will only allow one monitor on and the benq wont connect, but if I disconnect the wacom the benq works. I used another monitor connected by HDMI and it works displaying both monitors
Does anyone know why I would have an issue with one monitor not allowing to work if another one is connected.
