Display Problem with HD7850 after catalyst installed(weird screen)
niklas29
Hello,
my english is not that good sooo im gonna keep it short/simple.....
what happen?
this happen http://imgur.com/B3nAFDJ its not actual screenshoot of it but its close enough.... i think.....
what are you doing the time it happen?
I was playing the guild 2
what do you do after that
restart... but the only thing that shows up was blank black screen with some weird line and mouse cursor... same with safe mode but without the line
sooo the only thing i can do is to reinstall windows and i did that install process is going well with no problem... until i installed catalyst control center... restart... then... http://imgur.com/HKoXreP http://imgur.com/TKjpGgw and few seconds later..... http://imgur.com/NnNNm5E
is my graphic card dying? if so then what is good graphic card for $200?
win7 home premium 64bit
Core2Quad q8300
4gb ram
acer eg43m mobo
sapphire hd7850 2gb
Wow I've never seen that before but I'd agree that card is dead as my friend has a 7850 also.... For 200 you should try bump it up to 300 but either try find a 7870 or 7950. I sold my 7870 XT for $250 which you can buy a newer similiar model for $300 and you can play bf4 on ultra so you should consider saving an extra $100. But... make sure your CPU wont bottleneck it
im thinking of getting a msi gtx 660 or asus hd7870... or 750ti... or another hd7850..
and im sure my cpu will bottleneck all of the listed gc above lol
yeah it will, for amd you need a 6 core to run the 7870 as I had issues with bf4 that revealed it was just bottlenecking. I had to OC my fx4300 to 4.5ghz but it still had the same issue lol. Its properly time for a new build with those specs
