Hello,
Recently I have been working on reviving an old Lenovo FM1 motherboard found in my friend's attic (it seems to have the model number N1996). It had no RAM, cmos battery, CPU cooler, or chipset(?) heatsink on another die on the mobo. The CPU that was installed is an AMD A6-3600 APU. I mounted it in an empty Dell mATX case with another old Dell 300w Basetec power supply. I got some Adata XPG DDR3 1866 mhz 2x 4 GB dimms on ebay for it after some research suggesting 1866 mhz is what this CPU accepted.
I attempted booting into the BIOS (no boot drive) after plugging in the 24 pin and the 4 pin power connectors, installing an oem Dell GT 720, and installing the RAM. First I tried connecting to a monitor with the VGA plug on the 720. I shorted the power pins and a fan I had attached spun, and the CPU started heating up. Since there was no CPU cooler I hastily unplugged the power supply once it was evident there was no display signal. I next tried the VGA port on the motherboard - no signal. I used an HDMI monitor with the port on the 720 and later on the motherboard - same thing, no display. The monitors and the 720 are both verified working in other systems.
Any ideas on what a likely problem is? The possible issues I thought of were the lack of a CMOS battery or that the CPU died from overheating after being run with no cooler, despite only being powered for a few seconds at a time. Another possibility is that the motherboard is just dead. I also know there are much better PC building options to pursue for the cost, but I wanted to give it a shot since I have nothing really else to do right now and it would be a fun project. Side note, I've posted about this board before a long time ago before attempting to boot it but I can't find it in my past posts.
Thanks!
Thanks!
