This problem has persisted for quite a while and it's extremely annoying.
The hardware:
Screen randomly goes black (monitor reports no input) and the display won't return back unless I restart my PC by performing a hard shut-down using the power button.
This happens randomly, especially when running games (apparently the game being run doesn't matter; display can still die in very light games). Display sometimes does when sharing my screen.
What I've tried:
I'd really appreciate any help on this. I'm afraid of doing any work or playing any competitive games because of this. Methods of troubleshooting are very much welcomed as well.
The hardware:
- ZOTAC GAMING GeForce RTX 3070 Twin Edge OC
- AMD Ryzen 7 5800X
- Corsair Vengeance RGB Pro SL DDR4 (Part number: CMH32GX4M2D3600C18)
- ROG STRIX B550-A GAMING
- Corsair RM750x (2018) (Power supply in case you need it)
- Samsung SSD 970 EVO Plus 1TB (Windows installed here)
- ST2000DM008-2FR102 (Secondary HDD)
- Asus VG248QG with G-Sync (Monitor attached directly to GPU thru display port)
What I've tried:
- Increasing the fan curve to keep the GPU cooler. Display would sometimes die even when temperatures are well below 65C.
- Win + Ctrl + Shift + B. The beep is still heard but it does nothing.
- Ran Heaven benchmark on the highest setting to stress-test for 20-30min intervals. Temperatures would max out at around 70C but the display wouldn't die.
- Ran various other benchmarks; same result as Heaven benchmark.
- Re-seating the GPU.
- Installing the GPU in the other PCI slot.
- Updated Nvidia drivers.
- Tried installing various older drivers.
