Hi everyone. I got a Hanns G 22" monitor. It has DVI and VGA inputs. I connected it with the DVI to my custom PC with ASRock H77 Pro4 and a Radeon HD 5450. It has DVI and HDMI output. I had been running it with an old VGA only monitor until I got this one. When I connected it DVI, it worked, but the display comes out like there's no display driver. The resolution was stuck at 640x320. I uninstalled and reinstalled the graphics driver with the newest one and that didn't help. I tried changing the resolution, but it was stuck at 640 until I tried using the Radeon utility and got it to go up to 720x480. That's as high as it goes. When I tried to make it go any higher, it gives me a "Input Signal out of Range" message and reverts back the original setting. So now it's stuck at 720x480. I tried booting into safe mode, but I get nothing. I tried using the onboard video, but I still got nothing. It's only when I use the D-Sub that I can adjust the resolution. I tried to set the resolution in Safe Mode on DVI, but I get no signal.
Also, in the Display Properties in Windows, when you select the display, I see generic non-pnp monitor. When I click the "detect" button, it gives me another option from the drop down "Available display output on: AMD Radeon HD5450" when I select the HD5450, I get a list of properties that lets me choose from resolutions up to 1080p, but I can only get up to 720x480 59 Hz.
The monitor worked fine at work (I inherited it), but only worked on VGA, not DVI off onboard video. Is there a problem with the monitor? I don't have another cable to try. I have pictures, but I can't upload them here.
Thanks!
Thanks!
