Setup:
Samsung S27A950D connected to an Alienware M18x laptop running dual nVidia GTX 580M.
The M18x has a mini-DP connector so I have to use a short mini-DP to DP cable so that I can then use a standard male DP to male DP cable.
Problem:
When I connect with a 1.8m cable it works fine. I have tried two different 3m cables though bought from different sources and in both cases the PC detects the monitor but only displays on the laptop screen.
Workarounds tried:
I have tried using only the Samsung, switching off the laptop display and it still doesn't work - it of a long shot anyway since the GPUs should have more than enough power.
Also tried various other ways of fiddling with the control panel screen res settings to try to activate the monitor.
Any suggestions? I haven't heard of any issues with longer cables causing loss of signal with DisplayPort - I heard HDMI has that issue in the past but I understood that it would degrade the picture quality rather than getting nothing at all.
Be grateful for any input.
Problem:
Workarounds tried:
