Displays get more than GPU's maximum resolution
jefflynne
6
Hi,
I'm using this setup:
GTX 950 (specs: max res = 5120x3200)
2 X 1920 * 1200 together with
2 X 1650 * 1050
That's 4 DELL Monitors, work on 59 MH.
Is it possible, or am I missing something?
I'm not discussing the sharpness quality:
Question comes since I'D LIKE to change the smaller ones with 2 new bigger ones.
i.e. 4 of the 1920*1200.
Would this be possible?
Edit:
Thanks. I'd like to point out that all 4 are using the native resolution.
The idea is to keep the maximum resolution to 1920*1200 with all the four.
Hi. If the GPU's resolution gets more than display's maximum resolution, what happens ?
you know, I'm going to buy a BenQ GW2270H ( 1920x1080‎) and a MSI GeForce GTX 1050 Ti 4GT LP (
4320 × 7680 pixles) and so worried to not waste my money again for nothing 🙁
