DIY Wall Fan with Variable Controller
jhsu8888
47
I know this is kind of random, but trying to see if I can get a quick answer.
I'm looking for a way to create a very low air exchange setup in a closed system, and this is what I'm thinking
Combining a 120mm computer fan like this Arctic:
https://www.amazon.com/ARCTIC-F12-PWM-Rev-2-Controlled/dp/B00H3T1KBE
With a AC/DC 12V/1A adapter:
https://www.walmart.com/ip/GD-001-12V-Power-Adapter/111954350
And a low-voltage PWM controller:
https://www.amazon.com/RioRand-Voltage-Motor-Speed-Controller/dp/B00N30UK2M
I want low air movement, but not sure how much I will need, so I want to add some kind of motor controller and not sure if this type of PWM controller will work with a computer fan inline with a wall outlet. Will this work??
I also saw simple videos splicing USB cable (5V) to a computer fan (12V), but I wonder if getting the correct voltage AC/DC adapter is better.
Thanks!
The fan speed is adjustable with Arctic Breeze. There's a control knob on the fan base. And you can power it off from wall socket if you'd use USB wall charger, e.g like this one,
amazon: https://www.amazon.com/dp/B019ES6OJE/ref=psdc_12557637011_t3_B00GJI3L7Q
Though, feel free to go with your jerry-rigging way. The PWM control circuit board you linked does work with 4-pin PWM fans. Also, the Arctic F12 PWM fan is a solid fan with good CFM and low noise. I have used several F12 PWM fans with my PCs.
For low air moving, i'd go with 230mm 3-pin fan and DC control circuit board since 120mm fan has quite narrow airflow path compared to the more wide spread airflow path of 230mm fan.
Rather than jerry-rigging all that together with some good measure it not working right, why not to buy a small USB powered tabletop fan that also has RPM control included? E.g Arctic Breeze series (except Breeze Mobile),
specs: https://www.arctic.ac/eu_en/products/accessories/usb-fan.html
Arctic Breeze fan is a bit bigger than the Noctua NF-A8 PWM you linked (92mm vs 80mm) but it has good RPM range (800 - 1800 RPM) that you can adjust on the fly. Also, the fan has adjustable neck and it comes in different colors.
Doesn't quit meet my needs because there isn't a good way to attach to a box and speed is not adjustable. Thanks for the suggestion though!
Ok, Thanks for the input!
