G
Guest
Guest
Hi there
When I enable DMA on my hard drives and cdrom and then try and run zip files or setup files I often get an crc error or an I/O error. Occasionally files that were working are now apparently corrupted. Often, but not always, the errors seem to occur when the zip program is unzipping a large file (such as a .wad file). The problem occurs whether I try to install from cd's or copy the files from the cd to the hard drive and try and install or unzip from there.
When I disable DMA things work OK.
I have a western digital and a seagate Hard drive, and a Sony cdrom and Sony burner. The hard drives are on the primary IDE and the two cd's are on the secondary IDE.
I have an Aopen motherbord with a VIA Apollo chip, Celeron 466, 256 meg RAM and am running Windows 98. I have all the latest drivers from Microsoft for Windows and all the latest drivers from Aopen for the motherboard.
Any suggestions?
Thanks in advance
Noddy
Any suggestions?
Thanks in advance
Noddy
