Do CPU's need their own power source from PSU? or do they get their power from motherboard?
PedramCarter
270
I have an M5A97_R2.0 MOTHERBOARD ASUS, and 8350 CPU, does it need its own power source? or does it get the power from motherboard?
My specs are
my current specs that im building.
Vantage Midi ATX PC Gaming Tower
(The cooling system is developed for cooling throughout
4 x Built-in 12cm Fans (3 x Blue LED) will keep your components cool
Water Cooling Ready *not included* )
Processor (CPU)
AMD FX-8350 4.0GHz Socket AM3+ Octo Core
Motherboard
ASUS® M5A97 R2.0 (DDR3, USB3.0, 6Gb/s)
Memory (RAM)
8GB Ripjaws 2100MHZ (2 x 4GB)
Graphics Card
4GB AMD RADEON™ R9 290X - DVI, HDMI, DP - DX® 11, Eyefinity 4 Capable
(battlefield 4 edition, free bf4 included)
Memory - 1st Hard Disk
1TB 3.5" SATA-III 6GB/s HDD 7200RPM 32MB CACHE
1st DVD/BLU-RAY Drive
24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Power Supply
XFX 650W PRO650W Core Edition.
Processor Cooling
STANDARD AMD CPU COOLER
Sound Card
ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Wireless/Wired Networking
10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs.
USB Options
MIN. 2 x USB 3.0 & 4 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
You plug your CPU power leads from your PSU into where the red rectangle is on the picture of your motherboard. This is where the CPU gets it's power from:)
OMFG I THINK YOU SIR HAVE SAVED MY LIFE, NO WONDER MY NEW BUILT PC WONT GET A DISPLAY INPUT SIGNAL, IT DOESN'T TURN TO BIOS I WILL TRY THIS AND UPDATE YOU IN 60MINUTES <3.
Tried it still nothing :'(, I have a 6 pin and 8 pin connector on my r9 290x graphics card, it's currently plugged into 6 pin, but still nothing.
I updated the thread, added all the components, also you said there's a 6 pin, and 8pin, the problem is the PCI-E, there's 2 types, one is a 6 pin, and another is another 6 pin identical, but this one has 2 extra pins that look like have been snapped off the 6?, so if you understand there actually is an 8 pin one, but its 6+2, and they're not broken or anything but they're just next to each other, idk if they can be joined together or not to make 8.
6 pin and 6+2 = 14 PINS, all 14 pins are now connected to my graphics card, the fan spins, the DVI TO DVI connected from my GPU to monitor, still nothing, (on my GPU there's 2 DVI slot) plugged it into the top one.
bios doesn't respond or beep or anything :'(, CPU is now connected, CPU fan even spins, CPU is even connected, do you have skype by any chance, I can video chat you and show you?
I'm sorry I didn't mean to pick your answer as best answer, I accidently clicked it, but yeah fans spin, lights turn on, the motherboard even switched on, I even connected my case power button, and that works too.
I'm not really sure what else to suggest🙁
Please just check everything again.
Make sure the ram is pushed in correctly and has clicked into place.
Make sure the video card is pushed correctly into the motherboard.
Make sure the motherboard power lead and the CPU ones are plugged in and secure.
Make sure the video card in in the top Pci express slot in the motherboard. The blue one and not the black one.
:'( swapped the ram from blue to black, swapped GPU from black to blue, still nothing, GPU fan spins, but nothing, the motherboard green light is on, but still nothing.
