Do GTX 1070 Need Power supply? Is it necessery?
If it doesn't have a PCIe connector, it almost certainly isn't truly 500W.,
It's been covered off, you need a quality PSU with the appropriate connectors.
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($64.99 @ Newegg)
Total: $64.99
Generated by PCPartPicker 2017-01-04 16:36 EST-0500
Power...
Wait, Nipp__, you just bought this pre-built recently??? Can you return it?? If so, do that. That system is poor by late 2016/17 standards..... Given the spec/quality of components, if you paid more than probably $250, you definitely overpaid. I wouldn't even recommend that setup at <$250
What I would do is all I can suggest:
If you can't return it, I would attempt to sell it to recoup as much as possible and build something more appropriate. You're in the UK? It's going to cost you something like 400-500 GBP (minimum) to put something together that'll pair nicely with the 1070 you already purchased
Or, you could sell the pre-built & return the GPU, and we can help you work out the best components for your needs/budget etc.
