[SOLVED] do i have to buy 8pin graphics card power connector cable?
eziowar
417
14
18,795
hi does either corsair cs650m or gigabyte raedon rx 5600 xt come with 8pin power connector cable or do i need to buy it seperately? if so then which is best company for such power cords?
the power supply will have the needed connector. it has 4 pcie connectors so no problem at all running that card with it.
the gpu does not come with power cables as that is the responsibility of the psu.
ok. you need to buy cables that ar for the specific psu you have. there is no "generic" place to just buy cables. they have to be made for your psu to be compatible.
corsair sells cable kits.
https://www.corsair.com/us/en/Categories/Products/Accessories-|-Parts/c/Cor_Products_Accessories_Parts?sort=price-desc&pageSize=12&q=😛rice-asc:accessoryChannel:RETAIL:accessoryProductFamily:COMPONENT+ACCESSORIES#rotatingText
any of the generation 2 are compatible with your cs650m
Thank you soo much
