stevenbobdonut :
USAFRet :
stevenbobdonut :
USAFRet :
In general, yes, you would need at least one fan to pull the hot air out.
What case is it? Often, $40 for a new case is worth the headache trying to make an old one work.
A really really really old hp case.
There's this kinda ramp shaped tube that goes over the heatsink.
Right. I've had a couple of those.
Buying a new case will be far easier than trying to make that old one work well.
Will my pc overheat If I use that tube thingy?
Big green thing that leads to the back of the case?
A lot old Dells (and others) were made with that. On the original CPU, there was a simple, no fan, heat sink. That air conduit shuttled air from the heat sink to the back of the case where there was a fan pulling air out.
What case is it?
